Value of the Black spring
Old Mar 1, 2003 | 04:52 PM
NovaKaw650's Avatar
Default Value of the Black spring
While working on the 650 today, I noted that the belt is totally worn out and the deflection can be measured with a yardstick. The point is - with the black spring installed I'm getting no squeals, squawks, slippage or loss of performance. A very good addition to the 650.
Old Mar 1, 2003 | 06:27 PM
whereisthemud's Avatar
Have you guys that put the black spring in removed all your shims? I haven't installed the black spring yet but plan to. I did take out my narrow shim to get the belt in spec. Still has a thicker shim in it.
Old Mar 1, 2003 | 07:18 PM
Nightryder888's Avatar
i just put the black spring in and didnt tighten the belt. for some reason my belt was right in-line with spec. i dont know if i did the measurements wrong, but i plan takeing the cover off and tightening it over spring break. i think i might take the littler of the shims out
Old Mar 1, 2003 | 08:06 PM
nyroc's Avatar
I took out all my shims and the belt was so tight it pulled at idle. I left it that way because it bites down really hard, turns my big tires well. It squeals at idle.
Being tigh made my new belt last a whole lot longer than the first belt. The first one wore out at 500 miles, this one is still tight at 700 miles.
Old Mar 2, 2003 | 01:04 PM
2000MOJAVE's Avatar
I just for the life of me can't figure out why Kawasaki doesn't upgrade to this spring. With a new spring and some adjustable front struts the machine would be flawless instead of just awesome.
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
