what makes the pipes better?
Old Mar 1, 2003 | 06:22 PM
NEMISIS's Avatar
Default what makes the pipes better?
what makes one exhaust system better than another? is it the diameter or the way its bent?(the head pipe) im talking about 4 strokes more so than a 2 stroke. thanks
Old Mar 1, 2003 | 08:58 PM
SuzukiKidZ400's Avatar
Just better airflow
Old Mar 1, 2003 | 11:02 PM
NEMISIS's Avatar
with a naturally aspirated engine you need some back pressure. if that true?
thanks
Old Mar 2, 2003 | 01:11 AM
Bubba297's Avatar
Exhaust size and length still has a part to play in a 4-stroke, but a correct pipe for a 2-stroke can make them or break them. It's not so much backpressure on the 2-stroke, though. A correctly made expansion chamber actually bounces the waves back at the exhaust port just a split second before the piston covers it up. That pushes some of the raw fuel back into the cylinder for a more complete filling and that makes more power. Naturally the head pipe length will help determine the rpms at which the pipe works the most effectively, but these are just some of the basics. The reason why everyone doesnt just make a pipe is because there is a ton of R&D and money involved.
Old Mar 2, 2003 | 05:33 AM
DaBeechMan's Avatar
Its my feeling that there is a correct pipe for each motor. Production pipes will get you close to what you want, but not exactly. They say the first 10 horses are easiest power to make. Its the last 10 horses that will be the hardest (that in mind i know you guys make more then 10 horses initially). The last 10 horses has to do with the correct combo. If you want the power the pipe should be hand built. Bubba had it pretty close to a good definition on the correct way a pipe should be built, and how it should perform.
JohnnySplat
Aug 6, 2015 12:07 PM
zach1106
Jul 31, 2015 01:55 AM
Reactant
Jul 27, 2015 07:45 PM
traumajunkie
Jul 23, 2015 02:10 AM
cSchwartz
Jul 12, 2015 07:42 PM
