50W headlights
Old Mar 3, 2003 | 09:26 PM
Cat500i's Avatar
Default 50W headlights
I found 50W halogen headlights for a 03' cat 500i today. I had two of them go bad because the light housings are not totally sealed. The stockers are 27W.
Old Mar 3, 2003 | 09:41 PM
Cat500i's Avatar
Sorry, they are part #885 from O'Reilly auto parts. The stock ones are #880. The only difference is 50W versus 27W.
Cat500i's Avatar
Old Mar 4, 2003 | 08:44 AM
Cruez's Avatar
You might want to check the wiring for heat buildup after you get them installed. Thats almost doubling the wattage going through the wires that might not be up to the task. If anything you might put a relay to keep the load off the factory wiring.
Old Mar 11, 2003 | 08:22 PM
Bluethumb's Avatar
Aren't the lights already run through a relay? Should be. As for power consumption, I think the stock wiring is up to the task, but are the lenses? Lotsa heat off a 50W bulb. Seen a 500i the other day with 2[img]i/expressions/face-icon-small-shocked.gif[/img] 100W KC off road lights from a truck? Can't miss him coming, don't know how long his electrical system is going to last though. More light, more power, more diggin'!
Old Mar 11, 2003 | 09:56 PM
Cat500i's Avatar
I've run 4 55W lights before on an old Big Bear. I've seen several people run 2 110W off road lights on different 4 wheelers. I've never seen anyone or had any trouble myself with the wiring. I'm only running 2 of the 50W lights in place of the high beam 27W's. The lows are still the factory bulbs. I'm also running a spotlight from Wal-mart on the front rack. It's in the ATV section, comes with a pretty cool mount for about $30. I originally had it mounted on the handlebars and it worked great. It almost looked stock. I had to move it to the front rack because of the snorkel.
Old Mar 12, 2003 | 09:12 AM
Bluethumb's Avatar
Speaking of lights, my lights are aimed really high, looking up at the trees both on high and low beam, is there any adjustment there?
Old Mar 12, 2003 | 10:13 PM
Cat500i's Avatar
They are really easy to adjust. Remove the front grill. There are only 2 screws in it (star wrench) use the tool in the factory tool kit. Look to the left and right. There is a single nut. Loosen the nut, adjust, and tighten down. If you back the nut off all the way you can take the lights off for cleaning or whatever. Hope this helps. It really is easy.
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
