Prairie 360 belt on Prairie 650 does it works ? ?
Old Mar 4, 2003 | 01:40 PM
ConcoursQuebecCanada's Avatar
Default Prairie 360 belt on Prairie 650 does it works ? ?
On this forum a couple month ago I saw someone who put a 360 belt on a P650 .......any feeed back since. Is it working properly ? does it last ? do you have problem with grooves in the sheeves ? And when you instal this belt, wich is larger, what kind of spacer you have to install ?
C O N C O U R S
Old Mar 4, 2003 | 03:58 PM
NovaKaw650's Avatar
I don't know how that person made out. I do know that the 360 belt is wider at the top of the belt but the same as the 650 at the bottom, therefore the angle is slightly different. That might wear the clutch faces slightly faster until the belt wore down to the same angle as the 650 belt.
hugemoth
Jul 20, 2020 03:28 AM
timster911
Jul 13, 2015 01:57 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
bikedad3
Jul 2, 2015 02:15 AM
