SP 700 Carb. adj for K&N
Old Mar 5, 2003 | 04:18 AM
AVIG's Avatar
Default SP 700 Carb. adj for K&N
some ow my nassage is gone, so I'm writing again.
I installed K&N filter on my SP700 and the gas milage went down by 33%.
What did I do wrong?
Avi
Old Mar 5, 2003 | 06:58 PM
VeryPicky's Avatar
Are you sure that the K&N filter is the reason for the mileage drop or could it be something else that went wrong at the same time you changed filters? That is a huge drop in fuel mileage. If anything I would think that the K&N would give you better mileage. I would put the stock filter back on and check the mileage again. If fuel consumption is still worse than before, than it's not the K&N but something else. Take a look at the underside of the fuel tank and you will see two fuel hoses connected to fittings. Run your fingers around the fittings and see if you have any gas on your fingers. The fittings are known to leak. Mine did! Also, when you fill the tank with fuel, keep it around an inch or so below the neck of the fuel tank. If you fill it all the way up to the neck it will just run out the overflow tube, giving you false readings. While your at it, check for fuel leaks everywhere else that a leak could be possible.
Old Mar 6, 2003 | 02:10 AM
AVIG's Avatar
Thanks for your tips I'll check it today.
Avi
Old Mar 15, 2003 | 06:14 PM
Wolfhound's Avatar
? ? ? Any news....
Old Mar 16, 2003 | 02:40 AM
AVIG's Avatar
My mechanic "play" with the carb. and it didn't help so far. I have to mention that this trip after the carb adjusment was very hard lots of mud and boalders.\
\Avi
Old Mar 16, 2003 | 11:07 AM
Wolfhound's Avatar
Thank You for the update. I am very interested in the results....
Old Mar 17, 2003 | 02:34 AM
AVIG's Avatar
I got new Polaris standard filter and I'll use it this comming weekend to see if there is any differance.
and I'll let you know.
Avi
Old Mar 17, 2003 | 07:59 AM
Wolfhound's Avatar
O.K., Thanx for the inf.
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
