Another P650 question?
Old Mar 5, 2003 | 08:41 PM
sfehr's Avatar
Default Another P650 question?
In the yamaha forum someone wrote their review of the Prairie to the Grizzly and they state that when the belt light comes on after 100 hours of service the machine will only run at 3600 rpms. Now I know this happens when the belt is so loose or falling apart that it trips the sensor in the housing that causes the light to come on and only let the machine run at 3600 rpms but I was under the impression that the machine would still operate fine if the light only came on due to hitting the 100 hours since last belt service mark. Thanks for your help, Seth
Old Mar 5, 2003 | 11:04 PM
sfehr's Avatar
come on, one of you guys must of had the 100 hours of service belt check light come on, all I want to know is did this limit the speed of your quad or does it only get limited when the belt sensor is tripped?
Old Mar 5, 2003 | 11:36 PM
FrozenAKJoe's Avatar
If your service-belt switch gets tripped, I believe the engine will go into limp mode. I haven't had this happen, though. I've only got about 350 miles on mine.
Old Mar 6, 2003 | 12:02 AM
PRAIRIETWIN's Avatar
Still waiting for the 100 hour light to come on and slow my 650 P down.
I'v got 236 hours and 1685 miles on it. Still waiting for the LIGHT !!!!!!!!!!!!!!!!!!!!!!!!
I need to do the 100 service on it. How long does it usually take (in hours) for the 100 hour service light to come on ????????????????
Old Mar 6, 2003 | 12:03 AM
ChaosInMt's Avatar
This is only on the 03 it is a simple maintaince warning. NOTHING HAPPENS BUT THE LIGHT IS ON UNTIL IT IS RESET no rev limit 4x4 still works. It has no efect what soever other than the light and it is on solid not flashing. Is this all the Yamaha boys can come up with .
Old Mar 6, 2003 | 12:09 AM
sfehr's Avatar
ChaosInMt, Thanks for your help that is what I was wondering. I pick up my P650 on Friday and just wanted to know if I should not go on that ride that will put me over 100 hours till I have the proper service done to it first. Thanks alot for your help
Old Mar 6, 2003 | 02:16 AM
ChaosInMt's Avatar
No problem. It did freak me out when it happened to me. If you are worried about getting left in the woods I would dump the stock Dunflops. The stock tires suck and are flat prone. New wheels and the black spring and you are ready for the woods.
Old Mar 6, 2003 | 09:53 PM
yamaguy's Avatar
to all you guys wondering about that magic 100 hour mark, all I can tell you is what happened to my prairie when the light came on. About a week after I bought it the light came prematurely for some reason with only 8 hours on it. The motor started acting like it hit rev limiter. I took it to the shop where they pulled the tranny cover. The belt was in perfect adjustment and the belt sensor was in the "on" position where it is suppose to be according to the maintainence manual. The light simply malfunctioned, causing the motor rpm problem. I watched the mechanic pull it apart and saw it for myself. This leads me to believe that the rpm issue is directly tied into whether or not that light is on, not if the belt is out of adjustment consequently tripping the sensor on top of the tranny cover. Maybe I'm wrong or the mechancic was wrong, but I don't think so. If anyone else has this happen to them, please tell me, 'cause I'd like to know.
Old Mar 6, 2003 | 09:54 PM
yamaguy's Avatar
by the way, my light was flashing.....not solid, if that makes any difference?
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
