after market wheels
Old Mar 5, 2003 | 10:59 PM
CatKrazy's Avatar
Default after market wheels
I have a question for the cat lovers.
#1 I think we all know by know that the genusis at AC have designed a stock wheel for 03 that does not have a center cap. So getting a wheel that has the covered center is impossible unless of course you spend 400.00 and order them through AC.
My question
I need a wheel size to go by when i order my wheels. I need some that will allow enough clearance so my tires will not rub my shocks.
What do you have on your bike? I need the specs on them. I would like for them to be a chrome or alluminum wheel.
Any suggestions
Thanks
Old Mar 5, 2003 | 11:06 PM
maximus's Avatar
i too am trying to decide which to go with. i want alliminum to keep the unsprung tire weight down. i think highlifters new mud light rim has centercaps. i was thinking about either c-series or douglaus red label. does anybody know what the weight of the stock rims is
Old Mar 5, 2003 | 11:22 PM
CatKrazy's Avatar
Im just trying to figure out what size to tell them i need
Any suggestions?
Old Mar 6, 2003 | 12:36 AM
maximus's Avatar
12"rim and i am almost positive its a 4/115 bolt pattern. i would go with a 12x7 rim for the front and a 12x8 on back
Old Mar 7, 2003 | 10:06 PM
Cat500i's Avatar
Stock wheels are 12X7 front and rear. 4/115 is the correct bolt pattern. The backspacing will make a difference on how wide they sit. Don't know what the stock bspacing is. Saw a 500i at the dealer last weekend with Magnum aluminum wheels and some 26" Mudbugs. The wheels looked really sweet, but there expensive. Like $100 each. Don't know what to do with the centercap.
Old Mar 8, 2003 | 01:00 PM
PUSSYLOVER500's Avatar
WHAT YOU NEED IS 12X7 C-SERIES CAST ALUMIN. WHEELS I PAID 60 EA BUT THATS DEALER COST WHEN YOU ORDER THEM SAY YOU NEED 4 FRONT 12X7 C SERIES CAST ALUM. WHEELS
HAVE YOU EVER NOTICED THAT THE FRONT STICK OUT MORE HAVE FOUR FRONTS WILL GIVE YOU A 1" OFFSET MORE THAN FACTORY THEN YOU CAN PUT ANY SIZE TIRES ON YOUR CAT AND NEVER HAVE A CLEARENCE PROMBLEM.
[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 8, 2003 | 08:40 PM
CatKrazy's Avatar
***** LOVER
WHAT DO YOU MEAN HAVE FOUR FRONTS??
Old Mar 8, 2003 | 09:00 PM
Cat500i's Avatar
Are you saying that the offset of the front wheels is wider than that of the rear wheels. I thought the front suspension was actually a little wider. I've never had all 4 wheels off at the same time to compare them. What do you do about centercaps?
Old Mar 9, 2003 | 12:30 PM
ITP MAKES A CAST ALUM. WHEEL FOR THE CATS IF YOU GET 4 FRONT WHEELS IT WILL GIVE YOU A 1'' OFFSET FROM YOUR FACTORY STANCE AND THEY HAVE CENTER CAPS FOR THEM FOR ABOUT $4 PER WHEEL AND LUG NUTS FOR ABOUT $4 PER WHEEL THESE ARE GOOD LOOKING WHEELS FOR THE PRICE OF STEEL WHEELS. IF YOU WANT SOME I CAN HAVE THEM SHIPPED TO YOU CAL CHEROKEE AUTOMOTIVE (903)643-9453 GURANTEED TO BEAT ANYONE PRICES ON ALL YOUR ATV NEEDS.
Old Mar 10, 2003 | 09:50 AM
CatKrazy's Avatar
***** lover
shoot me a price for four with caps and lugs to area code 72364 Marion,Arkansas
email me at wmff82@aol.com
