Dropped a screw during rejet $*@%#$!!
Old Mar 7, 2003 | 11:02 PM
rty's Avatar
rty
Default Dropped a screw during rejet $*@%#$!!
Damn the luck!. While removing the airbox for rejetting my carb, one the screws that mounts the airbox to the top of the carbs fell down a hole and thru a hose. I don't have a service manual yet, but I believe the hose may be the crankcase vent. Yes, it did go all the way down the hose. What the heck do I do now? I don't know how in the world to get it out. What do you think it takes to retreive it? If I leave it, am I asking for a ruined engine later?
Help me out here guys!
Old Mar 7, 2003 | 11:23 PM
mastrblastr's Avatar
Tie a small magnet on a piece of fishing line. Drop it down the same hose. Pull it back up with the screw stuck to it and you're good to go. Hope it works.
Old Mar 7, 2003 | 11:39 PM
Scotia650's Avatar
I agree with mastrblastr's method, but if you pulled the hose off the case first wouldn't it be a shorter distance to fish it out? Also, if you could find a buddy with a small mechanic's magnet you wouldn't run the risk of losing the magnet in the case too. Either way, I wouldn't run the bike with the screw in it unless you want some serious engine problems.
Old Mar 8, 2003 | 12:01 AM
bigtimearcher's Avatar
If all else fails, change the oil!!!!!!! Maybe it will turn up?
Old Mar 8, 2003 | 12:49 AM
rty's Avatar
rty
Ah!!! The V-twin gods must have took pity on me 'cause I got that stinking screw out! I pulled the hose off and looked down the hole and there the screw was. It was turned with the head facing up and was caught. It never actually made it to the sump. It looks like the opening into the motor case necks down to a size smaller than the hose diameter. Much relief!!! Now I can concentrate on finishing the rejet.
Did get my muffler removed, cut the end cap off and drilled six 3/8" holes. The cap has been welded back, the muffler repainted and reinstalled. Only got to run it the shop, but it sounds sounds sweet. Much lower tone and a little louder. Almost reminds me of the V-twin on my Harley.
Thanks for the suggestions and help!
Old Mar 8, 2003 | 11:41 PM
roscoe69's Avatar
Yes the v twin gods have been good to you, now you must pay homage to them. You must give up sex or driving the 650 for a week or they will punish you.
Old Mar 9, 2003 | 12:42 PM
Scotia650's Avatar
Would have to be the sex. LOL
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
