Mojave motor redone
Old Mar 8, 2003 | 10:03 AM
mojavekid13's Avatar
Default Mojave motor redone
Iam getting my mojave motor rebuilt!
i was just woundering what was the best size to get it bore out to?
5th 4th 2nd??
I was thinking 2nd but will i see any power gain from my worn out stock motor??
thanks seann
Old Mar 8, 2003 | 12:05 PM
gaff's Avatar
just bore what it needs. The difference between .010" over or even a full millimeter won't be significant enough for you to worry about.
I did a megacycle kit not to long ago it was a huge difference. Can't remember what bore we went to but it was only what it needed.
If you go with 11.5:1 comp piston some cams and porting it will be excellent. But don't forget to factor in timing chain, Valves and possibly rockers and springs. Check out if powroll.com still has some springs and valves in there garage sale, they were pretty cheap.
Coherent poblem is pitting of the rocker arms. Megacycle refaces rocker arms but for the price you may find new ones to be an option.
Hopefully no crank or rod issues come about, but budget yourself $750 to $1000 to do a good job.
Ofcoarse FST offers the big bore kit, but that can be quite exspensive figuring the resleeve and case bore.
Old Mar 8, 2003 | 02:03 PM
I just want to frenishen it up some!
I dont want to go through all that!
I just want it to stop smoking!
Old Mar 8, 2003 | 02:04 PM
this was my plane!
Bore it to 2nd over size!
new valves and springs
and thats it
i already have a new camchain and things so!
what ya think
Old Mar 9, 2003 | 10:50 PM
mojaveaddict's Avatar
Just bore it to the first size. You will not be able to tell a difference between the 1st and 2nd bore and then you will not have the option to go to the second size next time. I suggest getting a wiesco in their 1st size.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
