Moisture in Speedo Problem
Old Mar 9, 2003 | 07:46 PM
Lo's Avatar
Lo
Default Moisture in Speedo Problem
I would like to know if anyone has found a way to prevent moisture from forming inside the Speedo. I'm on my second speedometer and both of them have had this problem. I know others have had it also. I would like to know how others are solving this if they are. I've heard about drilling a hole in the back of the Speedo. If this is how you fixed the problem I would like details. How long ago did you do this and is the Speedo still working etc. Thanks....
Old Mar 10, 2003 | 05:16 PM
DaveRuane's Avatar
I have same problem - it appears as a swoosh of fog in the lower part of speedo only. I wonder if it could be caused by heat from the various vent tubes that come into the headlight pod after terminating in the handlebar tube???
Old Mar 11, 2003 | 10:51 AM
1995400's Avatar
I have noticed fog in my speedometer also, the temp light has never come on, so I am assuming it is not overheating. Maybe someone will read this and offer some wisdom.
Old Mar 11, 2003 | 11:03 AM
Snowride's Avatar
Unfortunately it is a very common problem which can be annoying. Once the humidity is in it's almost impossible to get it out without drilling a small hole and letting it dry out then sealing it with silicone. Polaris knows they have a problem and switched to VDO for their supplier in 03. So far my VDO sealed unit is flawless but only time will tell. VDO LINK
Old Mar 11, 2003 | 11:27 AM
OLI600's Avatar
My 03 600 gets moisture in the VDO speedo everytime it runs.
Old Mar 11, 2003 | 11:42 AM
Farmr123's Avatar
Mine seems to have moisture in it for the last 5000 miles, but at least is still working fine.
Farmr
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
