nyroc's exhaust mod
hey guys what is the easiest way to cut off the end of the muffler I noticed it was weilded and is there any speacial type of weildeng to put it back on and can this be done without taking the exhuast off
Thanks
Thanks
I used a sawzaw and cut just behind the weld, because you would have a very hard time cutting through the weld. i used a mig welder to put it back on and i left my muffler and my rear rack on and had no problems, just take the fender extender off so you can get in there better.
As far as the sound i can't tell hardly at all. maybe a little deeper sound. I could tell a big performance difference. my throttle response greatly improved. i beleive that you would have gotten the same from an more expensive aftermarket product. i really was impressed, and glad i did the mod.
I drilled 6 1/2inch holes with a 12" bit. i drilled them really deep until i ran out of room. i did not bore out the end cap because i beleive that the end cap is the spark arrestor, so i did not bore it out. but after that i just welded it back on. i was really surprised of the power i gained. i highly recommend it if you dont want to buy a aftermarket pipe. i figured that i had nothing to lose, and being a college student i could use $200 on something i really need. i was really happy with the mod, and you could not even tell i had done anything.
