DS650 Question
Old Mar 12, 2003 | 09:33 PM
hoover650's Avatar
Default DS650 Question
where do the wires go from the clutch? *Baja guys, dont sell your lights..it only f*cks the buyer and seller*
When i press the throttle from a dead stop....it just dies.....
Old Mar 13, 2003 | 12:57 AM
hoover650's Avatar
HELP!!
Old Mar 13, 2003 | 01:15 AM
Hurycne's Avatar
I was the buyer does that meqan I get my money back?
Old Mar 13, 2003 | 01:43 AM
dunesled's Avatar
What did you do to it? Is it stock or did you do kind of mod to it?
Old Mar 14, 2003 | 12:13 AM
hoover650's Avatar
Antwain, you can hook them up, but as for me, im gettin the *** end of it....and if i had the money, sure you could get a refund but im as dry as hot glamis sand.
Somebody look on their DS and tell me where the 2 wires from the clutch go
Old Mar 14, 2003 | 12:33 AM
glamisds650's Avatar
the two wires go to a connector just in front of the top of the radiator, with them disconnected the bike will only start in neutral. connected it will start in any gear.
hope thats what you're asking.
Old Mar 14, 2003 | 12:39 AM
hoover650's Avatar
When i press the throttle from a dead stop it just dies! I dont know what it is..........does anybody know? have any ideas?!!!!??
HHEELLPP!!!!!!!!!!!!PLEASE!!!!!!!!
Old Mar 14, 2003 | 05:03 PM
hoover650's Avatar
PLEASE!!!! I NEED TO KNOW!!! SOMEBODY!!!
Old Mar 14, 2003 | 05:50 PM
so, are you saying that if the bike is moving that it will run?
if the bike doesn't run at all, when you give it throttle. I would first check and make sure there is no obstructions in the carb bowl that could be clogging the main jet. sand, dirt, varnished gas, etc.
then if that is clear and I was getting fuel to the carb bowl(needle not stuck, fuel line not clogged, tank breather line not pinched, etc) I would then remove the air filter completely. to see if I was just way too rich.
start there and let us know.
Old Mar 15, 2003 | 01:20 AM
hoover650's Avatar
Ok i just put on a new carb, the vents arent clogged, it has a new fuel line, and when i put the carb on it was cleaned and WD-40ed...? The fuel set up is FINE...it seems electrical...what would your bike do if the valves were way out of adjustment
