Cdale clutch cable
Old Mar 15, 2003 | 10:42 PM
GAR's Avatar
GAR
Default Cdale clutch cable
I found that the clutch cable from a 99 Yamaha WR 400 will work just fine. All that has to be done is file the threads down on the end enough to fit in the mount on the engine. Then adjust your free length. Works fine. I did shorten the threads by 3/8 of an inch to reduce the cable rubbing on the housing.
Old Mar 15, 2003 | 10:45 PM
dawzie's Avatar
Hey - thats good to know. Do you have a part number ?? Is it any longer than the dales ??
Old Mar 15, 2003 | 11:17 PM
GAR's Avatar
GAR
Sorry, no part number but your 426 cable could be the same. The WR cable is longer than the original cable that was one of the long one's not he new shorter version. I also think a Magura HYMEC clutch would work if I could turn the sensor right above the flywheel so the plug-in would be towards the front and not from the countershaft side.
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
craacker
Sep 9, 2015 04:32 AM
cdstang
Aug 31, 2015 07:52 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
