Raptor One-Way check - how painful ?
Old Mar 17, 2003 | 01:08 PM
FISHER1648's Avatar
Default Raptor One-Way check - how painful ?
How difficult is it to check the one-way for wear / abuse ? I just finished my 02 tranny conversion but didnt open up that side of the motor. Is it a quick job, or complicated ? Anything special I should know ? I havent consulted my trusty service manual but what is the general concensus of the level of pain ? It doesnt seem to be acting up but I'd rather check it for wear prior to a failure so I dont have any parts floating around my fresh engine.
Thanks, Eric
Old Mar 17, 2003 | 01:25 PM
Ward660R's Avatar
I haven't done it but I will when I do my tranny. If you decide to check it I was told to do it with the engine in the frame. Just going on how to do it, it doesn't sound like too bad of a job. I would if I were you.
Old Mar 17, 2003 | 03:05 PM
NotuRaptor2's Avatar
You will most likely need a replacement gasket. The real problem is that it doesn't seem to break due to wear per se - just bad luck when your spring decides to break. I've already seem some 2003 people posting with failed one-ways.
Do a search or look through some of the other recent posts on the topic. It isn't difficult at all.
/NotuRaptor
Old Mar 17, 2003 | 07:54 PM
FISHER1648's Avatar
Finally got a chance to peek at the service manual - looks like the the area where the one-way is located is pretty much separated from the rest of motor (tranny, crank, etc...). Am I correct in assuming that if the one-way flies apart, the loose parts should be contained within that side of the motor ? Also, once the generator rotor nut is off I should be able to remove the one-way without having to pull the magneto rotor - correct ?
Have you guys heard of any serious collateral damage due to the one-way failure ?
Thanks, Eric
Old Mar 17, 2003 | 08:35 PM
ctportedrap's Avatar
You cant just check it like that. You have to split your case. You would be better off just replacing it before it goes out. I just had mine replaced with '02 gears. I also had a JE piston 11:1 put in. Haven't rode it yet though.
'01 Raptor
K&N air / oil filter
JE 11:1 piston
Ported & Polished
Jetted
White Bros Graphics
Trail Tech bar clamp with speedo
Full Skids
Old Mar 17, 2003 | 08:57 PM
FISHER1648's Avatar
Ct,
Are you sure ? - we are talkin about the one-way bearing (starter clutch). I just converted the tranny to an 02 myself and that required splitting the cases but it seems the one-way is accseble behind the magneto cover (left side cover on motor) !?
Please clarify....
Old Mar 17, 2003 | 09:05 PM
warrior007's Avatar
Just the left side has to come off, nothing like the tranny.
if the one-way flies apart it will make all kind of noise. I doubt it will its more or less "contained"
There is a small passage between the left side case (one-way) and center cases (tranny and crank).
Old Mar 17, 2003 | 09:13 PM
FISHER1648's Avatar
007,
10-4, now that I think I have confidence in the tranny, I'm sorta waiting for the other shoe to fall as far as the one-way - if it aint one thing it's probably gonna be another [img]i/expressions/face-icon-small-shocked.gif[/img]
I'm just gonna ride hard and wait till I "hear" funny noises coming from that side of the motor....sounds like my new work wont be impacted if I open it up as soon as I start hearing bad noises related to the starter area - right ?
Old Mar 17, 2003 | 09:30 PM
warrior007's Avatar
More than likely it will just plain stop working and start spinning free. Or like mine and keep working but make whining noises all day long.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
