synthetic oil help for 650
Old Mar 18, 2003 | 09:48 AM
pdawg650's Avatar
Default synthetic oil help for 650
how many miles after break-in can you switch to synthetic oil .I have heard, from right after break-in to 500 mi.
Old Mar 18, 2003 | 11:11 AM
Kawi650's Avatar
I went to 900km then switched motul technosynth
Old Mar 19, 2003 | 12:08 AM
monteSS's Avatar
I switched to Mobil ! synthetic right after break in.
Old Mar 23, 2003 | 02:09 AM
Quadcrew's Avatar
I called amsoil and they say not to use to change oil until after breakin (p-650 is 10 hrs). I received the wrong oil (10w40) synthetic instead of the Motorcycle (10w40). Dealer advised both oils were the exact same packaged in different bottles???- Amsoil tech support advised the same thing??? Their webpage lists different technical specs between the two but they are the same price. I'll probably change mine every 20 hrs after the first oil change until it is used up. Should be very good break in oil for the money. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 23, 2003 | 11:44 AM
DustinMinnesota's Avatar
I changed at my first oil change or break in oil change and have experienced no problems. Just remember this however just because yo have went to synthetic this is a off road vehicle and you still need to adhere to the change interval due to contaminates in the oil.
I have 142 f and 145 r jetting in WV guys with the DG Snorkle and HMF Full System and it is seemingly correct did not move the needles just adjusted the air and the thing will throw ya for a mile hehe. Thought I would throw this in.
Old Mar 26, 2003 | 03:35 PM
NYds650's Avatar
I know on my DS650 I could not run synthetic because they say it is to slick for the clutch, can I run synthetic in my v-force since it is a cvt. Thanx
Old Mar 26, 2003 | 06:23 PM
monteSS's Avatar
Yes because it has NO oil bathed clutches in it just run the straight Mobil 1 synthetic. The V-twin oil is a waste and so is the 4XT (I think 10w40) it is formulated to be used with wet clutches. hope this helps.
MonteSS
cornermike
Aug 10, 2016 06:47 AM
Alex G.
Sep 19, 2015 06:34 PM
Haakon
Aug 24, 2015 01:54 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
toonces
Jul 31, 2015 09:27 AM
