another method for locking the crank and tranny bolts
Old Mar 19, 2003 | 06:08 PM
head1st's Avatar
Default another method for locking the crank and tranny bolts
We're looking at using this locking mechanism for hardware at work and thought it may work well for the crank and tranny plates. To bad I didn't come across it until I already red loctited my hardware.
http://www.nord-lock.com/
Old Mar 19, 2003 | 10:12 PM
mxmike's Avatar
Thats pretty neat.Seems like they could work.
Old Mar 19, 2003 | 10:54 PM
smitty911's Avatar
I'm trying to get some samples. If this is the easy fix I will use them all over my quad.
Smitty
Old Mar 20, 2003 | 02:52 AM
jschner's Avatar
Good find. These look really simple and would probably work. but, when you go to unloosen these things what will they do to the aluminum threads in the case when the bolt is pulled upward a bit? Also, if i'm reading the dimensions right, it appears with two washers they are 4mm high. I don't know if they will cause the bolt heads to interfere with anything and it looks like you will need to use bolts that are 5mm longer than stock to get the same bite in the case.
Old Mar 20, 2003 | 01:22 PM
NRATH's Avatar
I have some on the way. They have a stack height of .100" (.254mm). The OD is .53", which is just slightly larger than the screw. I'll be checking tonight to see if it'll fit in all the counterbores. I should have them early next week, I'll report on them when I get 'em!
Old Mar 20, 2003 | 02:39 PM
jschner's Avatar
OK .2 not 2mm each. Yes keep us posted.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
Haakon
Aug 24, 2015 01:54 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
