Wiring KLR250 CDI For Mojave
I'm planning to add Web racing cams to my Mojave. I recently purchased a used CDI from 1989 KLR250 (ebay $26!). I need to know how to wire this CDI to work on my Mojave. There are two plugs coming out of both units, the color codes seem to match. However, the KLR CDI has one extra red with black stripe wire. I assume it's necessary to swap the plug ends putting the corresponding colors from the KLR box into the Mojave plug. What should I do with the extra wire? Anyone have a wiring diagram?
you will notice in the seat of pants especially if you have cams and other motor work where you need the quicker advance. Will not improve top speed. will not hurt reliability unless it gives you a detination on accell that you did not have with the stock box. This can happen and if it does you will need higher octane fuel.
Mohave,CAN yOU add te ignition box out heavier valve springs ?I have a 2002,las tof the green frames LOL and its got kn filter,dyno jets big gun an thats it for now.I don t wanna float the valves tho just wanna lil bit more snap outta the bike.Also would playing w the fuel screw make any difference.Im hearing more an more bout that lil carb trick in the mags.
Mojave250A
Jul 11, 2015 10:38 AM
