cv joint problem
Old Mar 29, 2003 | 07:06 PM
ruger's Avatar
Default cv joint problem
I noticed today on my 650 that my cv boot by the wheel poppped off. So I took the whole shaft out and cleaned inside the boot and the joint itself because it sounded pretty gritty. My question is when I went to put the shaft back in, the little metal ring on the end that goes in the front end broke because I used to much force. Is there a trick to get the shaft in without hammering on it and not break the ring? Thanks for any help Brad
Old Mar 31, 2003 | 10:47 AM
littlecanuck74's Avatar
you were just being too aggressive you just put the shaft in and find the proper placing
you will feel it alide a bit and then jusat tap with a rubber mallet
just had to replace my boots as i ripped one had no problem
just be gentle with the next one
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
