Lakota reverse.
Old Mar 30, 2003 | 09:25 PM
Shortcut's Avatar
Default Lakota reverse.
My wife's lakota shifts into rev. without turning the ****? anybody ever seen this.
Jeff
Old Mar 31, 2003 | 01:10 PM
98Lakota's Avatar
Either the cable is rusted and will not release, the bracket that holds the cable by the motor has bent and will not release the cable or something in the trans has messed up. check the cable for movement first.
Old Mar 31, 2003 | 06:56 PM
2000MOJAVE's Avatar
I am not exactly sure how the Lakota is set up where the cable goes into the tranny, but on my Mojave there was "muck" under the cover where the reverse cable went in. I removed the cover, sprayed with lubricant and worked the rod back and forth with a pry bar until it freed up. I then put some grease all around the rod to keep moisture out. I would check your cable first though.
Old Mar 31, 2003 | 08:56 PM
Shortcut's Avatar
Thanks for the tips guy's ,I'll let ya'll know what I find.
Jeff
Reactant
Mar 30, 2022 02:08 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
neo27ny
May 14, 2018 12:19 PM
flyin-lowe
Dec 1, 2017 03:18 AM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
