Mud Lite handeling questions
Old Apr 3, 2003 | 12:30 PM
FastEd's Avatar
Default Mud Lite handeling questions
Guys,
I have just finished my first 2 rides with my new 26" Mud Lite tires. Observations so far:
Snow = Excellent
Mud = Excellent
Corners on hard pack = Much better than stock
Hard pack trails = rougher than stock, but better in a way.
Pavement = very twitchy handeling with pulling from side to side at 10 - 40mph. Scary at 40mph but smooths out over 45 mph.
What can I do to eliminate the side to side pulling.
Help!
ED
Old Apr 3, 2003 | 12:48 PM
Scotia650's Avatar
Check your toe-in, several guys have mentioned similiar problems from improper adjustment. Check nyroc's site for a straight forward guide to this procedure.
Old Apr 3, 2003 | 12:57 PM
nyroc's Avatar
Wobble on pavement is out of balance. You could do it well with a cheaper bubble balancer and stick on weights.
Too much toe causes jerk on uneven terrain.
Old Apr 3, 2003 | 01:10 PM
FastEd's Avatar
Nyroc,
Can you explain "jerk" on uneven terrain. I may have that as well. At slower speeds I feel like the machine is being pulled from side to side on the trails. With my stock tires I set the toe to 0. Do I need to re-adjust with the new tires?
ED
Old Apr 3, 2003 | 02:22 PM
crazzyjoe's Avatar
I have 26 in mudlites on my p650 and i got the front tires balanced when they were installed,they took alot of weight (all on the inside) and they are very smooth and they no vibration at all from the front end.
Old Apr 3, 2003 | 02:25 PM
Kawidan's Avatar
crazzyjoe
Same here. I have the 26" Mudlites and they are very smooth.
Old Apr 3, 2003 | 02:27 PM
92LT's Avatar
FastEd, what are the widths of your front and rear tires?
Old Apr 3, 2003 | 03:13 PM
nyroc's Avatar
If the toe is excessive, variable ground pressure and conditions caused by an uneven surface can cause a force on the tires that you feel as a tug on your handlebars. This has nearly zero affect on dry pavement.
This force results from a sideways force (due to toe) acting on the bottom of the tire, but producing a torque on the handlebar due to castor (tire pivot point is not right on the bottom of the contact patch, but forward).
Reducing the toe (whether toed out or in) will alleviate this. Try 0-1/6" toe in.
0-.79 may have been fine with crappy tires, but 0-1/16 is required by good tires.
Out of balance is always most easily felt on a smooth road. A combination of out of balance and excessive toe may cause you to have problems that seem not as clear cut as what I have described, but it really is this clear cut. It really is this easy to fix.
However, your tires are bigger and heavier than stock. You can't fix that without going with lighter tires. You may always feel a reduced nimbleness due to larger tires and heavier tires.
Old Apr 3, 2003 | 05:05 PM
FastEd's Avatar
Nyroc,
Thanks!
92LT the tires are 26-12-12 and 26-10-12
ED
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
