Cdale owners i need some help.
Old Apr 5, 2003 | 08:38 AM
coondog's Avatar
Default Cdale owners i need some help.
I'm a fairly new owner of a cannibal. Great timing right! I'm experincing a problem with my quad.It looks like i'm having oil coming from the air box through the air filter leaking down to the radiator. is this possible? I cleaned the air filter once thinking it was presoak with oil. But it's back again. Where is the oil coming from, how can i clear this up? thanks. I love my c'dale wouldn't sell for anything! It's truly a great machine.
Old Apr 5, 2003 | 09:06 AM
jbomb's Avatar
Go to Cannondaleriders.com. Go to the engine section in the forums and there is a thread on your problem.
Old Apr 5, 2003 | 09:35 AM
ezride's Avatar
There was an update to the engine crackcase, your dealer should have GAVE you the update , but they may have not known. Check out cannondale.com and technical bulletin TB02-009 386kb 2002 and 2003 ATVs produced prior to 7/16/02 7/16/02 Revised ATV crankcase ventilation routing.
Even though you buy from me just let me know and I can get you one.
Kip
(601)754-3309
Old Apr 5, 2003 | 12:15 PM
Sandgod's Avatar
Your oil level is to high. I had the same problem and was told to watch the level closer. I have done that and no problems since, even in a few moto's.. Update is the cure, but doesn't HAVE to be done. No engine or mechanical problems in a full year of ABUSE!!
Old Apr 5, 2003 | 05:21 PM
zwilldog's Avatar
what color is the oil? it could be too much oil on your filter
Old Apr 5, 2003 | 09:01 PM
Sandfan's Avatar
Three possibilities,
1. Oil level to high (best case)
2. Breather kit needed ( second best easy fix and not major)
3. when we had trouble with one of ours, found out the cartrige plate came loose taking out one of the pumps, causing a transfer of oil, thus blowing out the breather. ( bad news, major problem)
good luck!!
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
