Scrambler 400 problem
Old Apr 7, 2003 | 01:20 AM
4wheelr220's Avatar
Default Scrambler 400 problem
A friend of mine was riding his scrambler sat. and it started running bad and the temperature light would come on and he would have to stop for a short while to cool it off. The fan never came on so we figured it really wasn't that hot because the fan worked the day before. Then he was riding along pretty fast and it started running worse than it had before untill we heard a loud pop and a huge cloud of white smoke surrounded him. It ran better as soon as it "popped," but not there is a hole in the coolant reserve tank that you could stick your finger in. What could have caused this???? We have no ideas........
Old Apr 7, 2003 | 02:00 AM
modquad's Avatar
I've seen fans work intermittently. If your temp light is coming on, believe it, that means it's hot. I'm not sure if the newer design fans will fit, but maybe try to retro one in....that is provided it's an older unit. Also, whenever you wash your machine, backflush the radiator. Don't do this with a pressure washer, or you'll fold over your fins. Also, after flushing water through the fins, I sometimes take a blow nozzle with an extension and blow out the radiator from the rear. Now use some common sense here, hold the nozzle away from the radiator, or you'll fold over the fins with it also.
Old Apr 7, 2003 | 07:09 AM
vig's Avatar
vig
Sounds like a head gasket leak into the coolant, I had the same problem, only mine didnt blow a hole in the tank. Just would pour out of the resivor, and overheat.
Old Apr 7, 2003 | 11:37 AM
scramblered's Avatar
when the red light temp turn on,it is hotter than it can be and already too late...shut the engine and stop to work the fans or cooling down the
the radiator,but a hole in the coolant system will do that for sure....
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
