predator problems
Old Apr 8, 2003 | 06:13 PM
POLRACER's Avatar
Default predator problems
my predator is leaking grease on the rear axle by my sprocket. like the seal has gone out. anyone have this problem?? Also my brothers predator started leaking antifreeze out of the little weep hole above the hose and thermostat (where it goes into the head on the left side). was told this could be a blown head gasket or cracked head. both bikes have about 6 hours on them total. anyone have these problems? And what was done to fix? thanks for any info.
Old Apr 8, 2003 | 06:19 PM
STLKR27's Avatar
well i dont have a pred but my friend (works at a dealership) told me tht some preds were leaking antifreeze from some where cant remember where but that it was only lose a lose fitting. is there a bolt where the anti is leaking? if so try to tighten it up.
hope i helped but if not sry and good luck.
Old Apr 8, 2003 | 07:48 PM
modquad's Avatar
If you practice over-greasing the rear, the grease will bypass the seal. As long as the seal is in place, just wipe off the excess.
Old Apr 8, 2003 | 08:20 PM
pleasure4qt's Avatar
My TLD Predator 11/16/02 is leaking grease on the rear axle by my sprocket also. Like the seal has gone out.
It's done it since it was new and before I ever greased it.
My dealer is going to warranty it at a later date and perhaps put in all new bearings etc... if it is needed.
Has anyone found small holes in there seat covers perhaps from shipping staples or something????
Old Apr 8, 2003 | 09:54 PM
oaktree's Avatar
my predator did the same thing it was just a lose axle fade nut loosen the allen bolts and tighten it and the coolant is just a lose hose clamp.
1966F100
Jul 24, 2015 02:17 PM
hondarider1234
Jul 21, 2015 11:53 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
