more power on my sp400
Old Apr 8, 2003 | 08:17 PM
MuDmAnIa's Avatar
Default more power on my sp400
i have a sportsman 400 and it is pretty slow, it does have alot of pulling power in low but in high its slow to start and takes awhile to get up to speed does anyone know how i can get more speed/power with out alot of $$$$
Old Apr 9, 2003 | 12:14 AM
ftwflh's Avatar
Check out my signiture and see how my 425 is set up and thats will help out your power but it wont blow a 500HO but it will hang with them.
Old Apr 10, 2003 | 02:09 AM
ALANT's Avatar
fthwflh, I guess your magnum is a 4 stroke? For some reason they only make
an aftermarket pipe for the 425 magnum and not the 400 sp. I'm curious as
to how much more power that pipe helped your magnum. also the 400sp's
weight is a issue. i'm not sure but i believe its a lot heavier than your magnum.
I undertsand what mudmania is talking about with the 400sp it just lacks the
power in high. Any help from anyone would be nice.
Old Apr 10, 2003 | 08:06 AM
ftwflh's Avatar
My 425 is a 4 stroke(the same motor as your 400) and the pipe really woke it up.You might give Supertrapp a email and ask if they make a pipe for yours.They do get back to you i had to ask a couple questions of them.
Old Apr 10, 2003 | 07:46 PM
dusty's Avatar
Just for your information, a piston and jug from a 500 will bolt right on there. A wiesco 11:1 would make that puppy jump from a standstill. 465 cc 8)
Brian
Old Apr 10, 2003 | 08:02 PM
ScRaMbLeRiZeD's Avatar
Talk your dad into a pred bro! That will solve our problem.
Old Apr 10, 2003 | 08:50 PM
ftwflh's Avatar
Hey dusty if he wants to get into the motor a 500HO cam and 38mm carb will do a number too.Pluss its easier and cheaper than a jug swap.
Old Apr 10, 2003 | 10:11 PM
punkrockrider's Avatar
just get a clutch kit and exhaust..........that would solve your hole problem........when you push the gas the response time is horrible......the clutch makes it go when you push it.......and exhaust should give you a few more hp.... check out www.hotseatperformance.com they have nice stuff
Old Apr 10, 2003 | 10:13 PM
NOTE: that would be your cheapest way to go.... for alot of low end power....
Old Apr 10, 2003 | 10:18 PM
Thats the problem punkrockrider. My brother (mudmania) is cheap! He wont buy that for himself.
