very,very lean whats better , jets or dial-a-jet
Old Apr 13, 2003 | 05:39 PM
prairievenom's Avatar
Default very,very lean whats better , jets or dial-a-jet
need help. Wich is esier to install.
Old Apr 13, 2003 | 06:30 PM
crazzyjoe's Avatar
Just woundering why would you put (#uck nascrap) and nascar sucks a$$) in your user profile?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 13, 2003 | 08:06 PM
Vforcer's Avatar
how lean ??? the dial-a-jets will only make up about 2 jet sizes.
I put in larger jets ...... and then use the dial-a-jets as the easy adjustable jet to fine tune with.
Old Apr 13, 2003 | 08:30 PM
i have all the mods listed, im back firring through the carbs.
I dont like NASCRAP cauze of all the attion it gets, and they dont do nothing but race family sedans in circles. If you want to see real racing league you should check out the American lemans series (www.americanlemans.com), trans am series(www.scca.com) and the rolex sports car series . All of these series have cars like audi. panoz,corrvette,porche,viper,lola,bently bmw,ferreri, and a whole bunch more ( i just cant remeber them). Thease cars are the worlds fastes sports cars. they can do 0-100 in 4.5-6.0 seconds. and there is a whole bunch more passing do to differnt clases.
i need to know wich is easer to install cauze im only 15 and im not very good with machiens would appreciat any feedback .
IF YOU WANT TO SEE REAL AUTO RACING YOULL CHECK OUT THE LEAGES I MENTIOND
Old Apr 13, 2003 | 09:36 PM
Vforcer's Avatar
Prairievenom
If you cover up the holes in the air box .... does it run ok ?????????
The question was .... which was easier ..... I would say about the same ....just different.
I think I remember that on the P650, that I had to take the carbs off to change the jets.
The dial-a-jets involve putting 4 holes in the bottom of the air box...... run two hoses to the bottom of the carbs.... and two hoses for the snorkles. You also have to drill and mount brackets to the bottom of the
air box for the induction jets.
Old Apr 14, 2003 | 07:00 PM
THANKS FOR THE HELP VFORCER. I DONT HAVE HOLES IN MY AIR BOX. DOES THE DIAL-A-JET COME WITH INSTRUCTIONS ON HOW TO INSTALL.
Old Apr 14, 2003 | 07:17 PM
Vforcer's Avatar
It does come with instructions.......
When mine is spitting back in the mid range .... It needed more air to cure it.
You might try removing the lid .... re-installing it with the two back clips under the lid to
prop the back of the box lid open a bit ........ If it runs better , it needs more air. If it
runs worse, it needs more fuel.
Old Apr 17, 2003 | 08:42 PM
250xRKrider's Avatar
hey prairievenom, i would also say in your case go with the dial-a-jets for the easier instalation. i just used the jets but i think that the dial-a-jets should work just fine in your case. tell me how it turns out.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
