First oil change on Raptor
Old Apr 20, 2003 | 01:19 AM
duner2003's Avatar
Default First oil change on Raptor
Holy cow, whoever designed this set up should be fired, what a pain. Have to take the skid plate off to drain the engine, and how are you suppose to drain the oil tank without making a huge mess. Oh well its done, next time will be easier, I hope.
Old Apr 20, 2003 | 03:29 AM
THEMOOSE's Avatar
just trim out a hole for the engine drain & put a small catch pan under the tank.
When new I changed oil & filter every 5 hours till I hit 20 hours, after that it was every 20 hours for an oil change & valve adjustment.
Old Apr 21, 2003 | 03:52 PM
Travandang's Avatar
why do you'll change the oil so often? I have a 2003 kodiak 450 and the manual says to change the oil after the first 20 hrs and then every 1,500 miles or 150 hrs.
Old Apr 21, 2003 | 04:26 PM
THEMOOSE's Avatar
Well unlike the Kodiak My Raptor is a high reving high preformance engine that takes a lot of abuse in drag racing & sand dunes so it's a lot harder on the oil so it needs changing more often.
Also oil is cheap & a seized engine isn't!!
So I change oil, clean the Scotts oil filter, put in a new spark plug & adjust the valves every 20 hours.
Old Apr 21, 2003 | 05:54 PM
RaptorCam's Avatar
I agree! I took a 20 oz. plastic soda container, cut the bottom off and then cut out a v shape lengthwise on one side of it. I stick it through the skid plate from the bottom and unscrew the bolt--oil drains right down through, no mess. Cheap and simple [img]i/expressions/face-icon-small-happy.gif[/img]
Kaleb_00
Jun 1, 2016 09:15 AM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
