Dialing In Raptor
Old Apr 20, 2003 | 06:15 PM
shmoo's Avatar
Default Dialing In Raptor
Well. This weekend was the first time I could get out to test my bike with the new mods. I have to tell you I went by everyones opinions and could not get it dialed in with the lid on. I ripped the friggin lid off put in 160/165 Mains and 27.5 Pilots. I had to take that damn tank off about ten times to adjust the air fuel mixture. Finally after all that I ended up with 3 1/8 Turns out Left and 3 3/8 out Right. When I tryed it 3 L and 3 1/4 R Too Rich, tryed 3 1/4 L and 3 1/2 R too Lean. I didn't know that little bit would make a difference. Now, when I run through full throttle I get no bogging and no popping and snapping. My plug is very very lightly tanned. Does it sound like I have It dialed in now, or what I am asking is would you know if the bike is dialed in just my riding and having no bogging or popping and snapping, just good pull from the bike. Also It is 72 degrees out, will I notice a differnce once it hits 80 or 85.
Thanks
Old Apr 20, 2003 | 11:44 PM
GregV's Avatar
Did you skip past 25's on the Pilot Jets??
How does your head pipe look while it's idling??
Old Apr 21, 2003 | 08:38 AM
shmoo's Avatar
25's were a bit poppy when blipping the throttle. I never noticed what the headpipes looked like while idling. The bike pulls well through full throttle but my plug is very lightly tanned.I am going to take a pic of it today and post it.
Thanks GregV
Old Apr 21, 2003 | 10:09 AM
shmoo's Avatar
I have added pics to my gallery so if you click on the camera it is the last 3 pics.
Thanks
Old Apr 21, 2003 | 10:15 AM
shmoo's Avatar
I can't see the camera below my name on my computer so if you can't just look me up in the gallery.
Old Apr 23, 2003 | 12:29 AM
GregV's Avatar
Your head pipes will glow a little red right at the beginning of the bend, as long as the redness is 6" or less you are in good shape. You can let it idle for a few minutes and take out the plug and see what it looks like to see how your pilots are doing.
So, when you rev it hard from idle it comes in smooth and doesn't stumble?? If your plug looks good durring idle and you don't have a stumble when hitting it hard off idle.....you should be fine. Personaly, I'm running 25's because my headpipes would glow ruby red!! I went to the 25's and "problem solved".
Old Apr 23, 2003 | 12:50 AM
GregV's Avatar
Hey Shmoo.........from what I can see it looks pretty good.
I have a specific question for you, click here.
Old Apr 23, 2003 | 08:38 AM
shmoo's Avatar
I am gonna do an idle plug check this weekend. I will let you know the plug color around the base and the state of the headpipe after idling. How long should I le t it idle for to get a proper reading.
Thanks
Old Apr 23, 2003 | 08:41 AM
shmoo's Avatar
I think it might have been a bit black around the ring area where you pointed out in the pic.I'll keep you posted after I do that idle plug check this weekend.
Old Apr 23, 2003 | 08:54 AM
RhondaV's Avatar
4 or 5 minutes should be fine on idling.
Just make sure you don't have black flakes on the base ring. The porcillin looks good, but that only indicates fuel detonation.
GregV (on RhondaV's computer)
