cooling fan on traxter
Old Apr 21, 2003 | 09:05 PM
tekneek11's Avatar
Default cooling fan on traxter
Could someone please tell me how to check if the cooling fan is working on my 99 traxter.Is there a fuse or a way to run it manually?Thanks mowing seasons comin and my bomb does 5 acres no problem.mrlizzzard@yahoo.com
all the best!null
Old Apr 21, 2003 | 09:43 PM
racerx5x5's Avatar
Hi, I have a manual on cd pm me if you want one. ($7)
Old Apr 21, 2003 | 09:52 PM
racerx5x5's Avatar
Section 05 ELECTRICAL
Subsection 07 (INSTRUMENTS AND ACCESSORIES)
05-07-5
TESTS
12-VOLT AUXILIARY POWER
OUTLET
Using a multimeter, measure the voltage between
RED/BLACK and BLACK wires.
The obtained value should be between 12 and
14.5 Vdc.
– No voltage:
• Check fuse no. 2 and wiring condition.
– Voltage is good:
• Check outer accessory.
12-VOLT POWER OUTLET
Remove the steering cover.
Unplug the power outlet connectors.
14.5 Vdc.
1. 12-volts power outlet
2. Power outlet connectors
– No voltage:
• Check fuse and wiring condition.
– Voltage is good:
• Change power outlet.
COOLING FAN OPERATION TEST
Unplug the temperature sender connectors.
Install a jumper wire end in each connector. Replace
the fan if it does not work.
HEADLIGHT
GREEN/ORANGE and BLACK wires.
Start the engine. The obtained value should be between
12 and 14.5 Vdc.
NOTE: In diming mode, the obtained value should
be between 7 and 10 Vdc.
– No voltage:
• Check wiring condition and HI-LO switch.
– Voltage is good:
• Change headlights.
HI-LO SWITCH
Open multi-function switch box.
Using a multimeter, measure the resistance between
the following wires.
Replace switch if defective.
1 2
V01G0GB
POSITION WIRE RESISTANCE
Switch released
BLACK
and
BLUE
Infinite (0.L)
Switch
depressed
and held
0.4 W max.
V01G0DA
Old Apr 24, 2003 | 11:13 AM
tekneek11's Avatar
Racer e-mail me mrlizzzard@yahoo.com I'll send adress for cd.Do you think that the "ice antifreeze would work and let the fan stay down?lemme know
all the best!
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
