02' Grizzly 660 boiling gas
My wife asked recently if anybody had heard of this problem and the responses were lost.
This sympton was noticed after a stop from an extreme uphill 4 x 4 climb with 200lb = rider. I know the exhaust header is
real close to the plastic tank but never dreamed it would get that hot. Thanks
Yeah dude, I never believed that crap for a good while, and then witnessed it and felt stupid. I took off the gas tank and just went over the bottom of it with reflective heat tape (real cheap crap too, like $3 from a hardware store- foam with the reflective stuff on one side). Then I wrapped the header pipe all the way past the carb with highlifter heat wrap. That did the trick I guess, cause I've never had another episode or any sputtering or cutting out. That was over a year ago too.
I have a '02 and did the same thing, my brother in law has a Brand new one and also did it! Yamaha offers a kit for this problem...it consists of a heat shield that goes under the tank and a sleeve for the fuel line, and a seperate side panel kit that has been slotted on the sides...its cheaper to modify your stock ones and are better grade plastic, a person from a dealer showed me hoe to slot them and it SOLVED this problem! The heat shield piece for the tank is only $7.00!
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
