Kodiak Ultramatic
Old Apr 30, 2000 | 09:33 AM
rogi's Avatar
Hi I would like to know your general feelings on the Kodiak ultramatic. So far I had no problems with it and lots of fun, I prefer it more then my Wolvrine I owned before. Can't really find anything wrong with it apart that it slow. I honestly thought its speed would of been somewhere near those of the Wolverins, but its not!
rogi (y2k Kodiak)
Old Apr 30, 2000 | 12:39 PM
Tim1's Avatar
I would not call 50mph slow it is just that you are used to a 60mph wolverine which is faster than most bikes even with larger motors.
Old Apr 30, 2000 | 06:00 PM
Ridgerunner450es's Avatar
I have a Kodiak that will go 51 mph,and a Honda450es that goe's 47 mph so I consider the speed of the Kodiak very good for 401cc engine.
Old May 1, 2000 | 10:12 AM
tsz's Avatar
tsz
Rogi I bought mine a month ago and took It out yesterday for the first time . It was running fine under power but when stopped to a idle It would stall.Then there is the problem of getting It into neutral. I had to rock It back and forth to get it back to obtain the neutral start position.Can someone out there offer some tips.I also noticed that It was quite loud when my son was driving through the bush.
Old May 1, 2000 | 12:37 PM
snowshark's Avatar
50 mph is plenty fast for a utility quad, my Rancher tops out around 50-51mph. If you want more speed then go for a sport quad.
The BIG utility quads like the Griz & Polaris sportsman & magnum can't do 60 mph.
Old May 1, 2000 | 04:33 PM
JHAM's Avatar
I'm extremely pleased with mine and I thought it was fast but I did have a 250cc before. It's smooth shifting from reverse, high, low and in and out of 4x4. The 4x4 in low range is killer in WV hills, I can creep down huge mountains without hitting any brake.
Old May 1, 2000 | 05:22 PM
Tim1's Avatar
Get it looked at.I tired a friends 2000 Kodiak and it shifted really smooth.
Old May 1, 2000 | 09:36 PM
Smokinthebear's Avatar
Not trying to be 'funny' but you stated getting it back to the neutral start position, you do know that it will start in any gear if the left hand break is pulled all the way in dont you?
Old May 1, 2000 | 10:02 PM
Mac's Avatar
Mac
Well, Rogi I'am wondering about the new Kodiak too!! Is it hard to change the oil filter?? Air filter?? Notice there isn't any speedo or trip. Did you add one or has anyone installed one or had the dealer do it??
Mac Big Bear SE 4X4
Old May 2, 2000 | 12:40 PM
rogi's Avatar
ask the dealer to check it, it might be something very simple to fix...as for the noise, Yes the Kodiak is fairly load-good luck
rogi
