What the hell does a case saver do? Lectron Carb
Old May 6, 2003 | 08:22 PM
macentyre's Avatar
Default What the hell does a case saver do? Lectron Carb
Hey what does a case saver do?...
And are the 40mm lectron carbs good?...better or equal to a Keihin 39mm FCR?
Thanks guys..
Mac
Old May 6, 2003 | 08:41 PM
250xrida's Avatar
It protects your case if your sproket breaks, i think...
250xrida's Avatar
i mean if your chain breaks my bad..
Old May 6, 2003 | 08:47 PM
DaBeechMan's Avatar
Yeah, it saves your case if a chain breaks and swings around and slaps your case. Sometimes it works, and sometimes it doesnt. but its a healthy 30 dollar investment.
Old May 6, 2003 | 08:58 PM
RacinJason's Avatar
Great investment...the new EX's have a steel saver already installed...I put an aluminum pro-design case saver on the raptor and when the chain broke going off a jump it wadded up between the frame and C.S. The case saver did its job and saved me a ton of money and time
Old May 6, 2003 | 10:51 PM
yellowexracer's Avatar
Anyone know if there's a case saver that works with a 16 tooth sprocket?
Old May 7, 2003 | 09:13 AM
95wolv's Avatar
Same here, I put a 14 tooth on my son's 300ex, and had to take the stock steel case saver off to get it to fit,don't like the idea of running without one.
Old May 7, 2003 | 02:40 PM
RacinJason's Avatar
The pro-design was thick enough on a 400ex to grind/shave enough material to allow clearance Clarence.
Old May 7, 2003 | 05:57 PM
DaBeechMan's Avatar
On 250r's there are no case savers that allow a 16th sprocket. Even if there was there was a case saver there wouldnt be enough material on it to save the case
Old May 7, 2003 | 08:20 PM
PUSHINTHELIMIT's Avatar
I just did a little grinding on my case saver when i put a +1 bigger sprocket on.
