reverse rev limiter on 03 raptor
Old May 7, 2003 | 10:58 AM
RoostinRaptor's Avatar
Default reverse rev limiter on 03 raptor
do any of you guys know a way that i can bypass the reverse rev limiter on my raptor. every time the tires break loose it kicks in and that sucks because if you on a hill you cant get out of it.
Old May 7, 2003 | 11:26 AM
mtecate4g's Avatar
Check out ebay. My bro bought a kit off of there for his Raptor and Grizzly it works great!
Old May 7, 2003 | 12:13 PM
RaptorOwner's Avatar
I got the same kit if you want it, I dont want to rig that up on my bike. There has got to be an easier way.
Old May 7, 2003 | 12:17 PM
GYTR's Avatar
I will sell you mine for 10.00 and ship it to you for FREE. Let me no if you want it
Old May 7, 2003 | 12:55 PM
hey GYTR ill buy it from you get back to me on this. my e-mail is z400rider2002@yahoo.com so e-mail me or just get back to me on here.
Old May 7, 2003 | 03:04 PM
GYTR's Avatar
Check your email
Old May 7, 2003 | 04:16 PM
Guest
Guest
Posts: n/a
follow the wire that goes from under your gear shifter (the one that has the cap that looks like it will come off, not the one with the phillips screw), up to near the airbox, then splice that wire nad have the wire that you are adding go the the airbox bolt, this will ground it out. Put some dialetric grease on the splice and the airbox bolt so that any water that gets there wont ruin you're connections. When you do this there are 2 defects 1)you can start your quad when it isnt in neutral and 2) the reverse light doesnt go on when youre in reverse, hope this helps,
Patrick
Old May 7, 2003 | 05:32 PM
ok, so that has something to do with starting it in gear? I thought that was the switch on the clutch handle.
Old May 7, 2003 | 06:09 PM
Guest
Guest
Posts: n/a
Honestly, I havent tried the starting in gear thing, I've only heard of it. I guess since it disenages the limiter that it also bypasses the safety that makes starting in gear impossible. I did this to my quad and it works great, just make sure you waterproof it,
Patrick
Old May 8, 2003 | 12:55 PM
hey GYTR ill send you the money tomorrow. ok is this a home made unit or is it something that you bought.
