***** Who makes the motor for Arctic Cat ATV's? *****
Old May 9, 2003 | 11:51 AM
SmokinBarrel's Avatar
Default ***** Who makes the motor for Arctic Cat ATV's? *****
Anyone know who makes the motor for Arctic Cat ATV's? is it Arctic Cat or a competitor? Specifically, the utility models.
Old May 9, 2003 | 11:57 AM
Raptoryfn660r's Avatar
RIP Dear Friend
which owns 26 percent of the American manufacturer.
Old May 9, 2003 | 01:22 PM
ttaylor's Avatar
Suzuki makes the motors.
But AC lowers the compression ration by placing a larger gasket between the cylinder and the head. Also Suzuki adds a plasma coating to the cylinders which AC doesn't. They also use different carbs too.
If you compare the AC 500 motor with the Suzuki Vinson Motor
or the AC 400 (375) with the Suzuki Eiger.
Old May 9, 2003 | 01:39 PM
Olddirtybastard's Avatar
Originally posted by: ttaylor
Suzuki makes the motors. But AC lowers the compression ration by placing a larger gasket between the cylinder and the head. Also Suzuki adds a plasma coating to the cylinders which AC doesn't. They also use different carbs too.If you compare the AC 500 motor with the Suzuki Vinson Motoror the AC 400 (375) with the Suzuki Eiger.
Taylor your statement is correct for the 02 models. But the 03 AC 500 specs are identical to the Vinson.
In 03 AC and Suzuki 500s both have the same engines with 10.2:1 compression, Keihin CVK36 carburetors, the exact horsepower and torque ratings. Even the same final drive gear ratios.
Old May 9, 2003 | 03:07 PM
ttaylor's Avatar
I guess I am a little behind the times. Sorry!!
Do you know if they use the same transmissions now on the autos?
Old May 9, 2003 | 04:09 PM
I am not sure. They look the same but I have been unable to find the specs on the Suzuki transmissions to compare.
Old May 9, 2003 | 05:03 PM
HONDAJAS's Avatar
I believe that suzuki even makes arctic cats snowmobile engines. How would a Suzuki brand name snowmobile sound? I think pretty crappy [img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 10, 2003 | 03:53 AM
LEP7MM's Avatar
believe it or not, Suzuki did used to have their own snowmobile. The one that comes to mind is the 440 Fury. If I remember correctly, it was also "liquid cooked". Fast machine for their time.
Old May 10, 2003 | 11:41 AM
2000IAWarrior's Avatar
yes suzuki did at one time make a sled a 440 my dad remembers his ol suzuki sled that and his old Rupp 440, but suzuki makes cat engines in atvs not sure about sleds!
if any one has pics of the suzuki 440 sled let me know
Old May 26, 2003 | 01:58 PM
J3nut's Avatar
I just sold my 1994 sled with a Suzuki engine. I believe most if not all AC sleds with watercooled triples are made by Suzuki. Mine was an 800 and is a screamer!!!
