OMW DS650 Dyno Chart
Old May 9, 2003 | 08:23 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Default OMW DS650 Dyno Chart
Here ya`ll go!! Click here!
Old May 9, 2003 | 08:31 PM
BLASTERDEVIL2's Avatar
nice flow. so you lost a little on the bottom. but what a improvement. congrats.
Old May 9, 2003 | 08:33 PM
Forcefed's Avatar
Thank you.....yeah, since the bike is never going to see anything other than 200-300ft runs, I was willing to give up some down low! Here is a couple of pictures from this year!
OMW DS650 on the dyno
Sideview of OMW DS650
OMW wheelybar and studs.
TM45 and K&N airbox removed
Old May 9, 2003 | 09:07 PM
VEGAS650's Avatar
Did you get larger valves?
I see this alot with the larger ones. Lose bottom but pick up tons on top!
Great job!
Old May 9, 2003 | 09:09 PM
1BigDSRider's Avatar
Who needs bottom end when drag racing. ITs all about high Rpms.
Old May 9, 2003 | 10:15 PM
Forcefed's Avatar
Valves are bigger, cams are bigger, springs are bigger, ports are bigger, carb is bigger, exhaust is bigger, and the grin factor is MUCH BIGGER!
Old May 9, 2003 | 11:47 PM
Hurycne's Avatar
Nice...thanks for backing up those numbers!!
Hurycne's Avatar
Had to hog out that needle tube I bet for that alky
Old May 10, 2003 | 11:26 AM
SpinCycle's Avatar
It's all about AREA UNDER THE CURVE!!! nice.
Old May 10, 2003 | 04:29 PM
Forcefed's Avatar
Hurycne.....those numbers are on gas. A 48mm Lectron was swapped in for the Alky runs which showed gains of about 9 more RWHP. I think we could have squeezed some more out of the Alky....but the dyno clock was ticking and I intend on sticking with high octane fuel dou to class restrictions. Thanks again guys.
