Wtf is up with my coolant line?
Old May 10, 2003 | 01:14 PM
AdamsBadDS650's Avatar
Default Wtf is up with my coolant line?
The top coolant line that connects to the head keeps blowing off. The hose clamp is tight, and it only does it when I rev the motor really high, like in a drag race. but it's done it like 5 times now. It blows off of the other end of the hose, hot where it attaches to the head, but where it attaches to the pumper-thingy. Any ideas of how to get it to stay on?
Old May 10, 2003 | 01:17 PM
RaptorOwner's Avatar
That dont sound good.... Has it gotten hot? It almost sounds like a head gasket leak into the coolant an causing it to blow off. Let us know what you find out.
Old May 10, 2003 | 01:20 PM
warrior007's Avatar
yeah with that much pressure in there you would see it at the reservoir too, I say had gasket or..... bad radiator cap?? it should relieve anything worse trhan 16psi.
Old May 10, 2003 | 01:22 PM
No, it's not that, because I had those clear coolant lines on it, and the coolant was flowing fine, but it kept blowing off, so I changed it back to the stock ones. Now it's still doing it.
Old May 10, 2003 | 02:36 PM
RacinJason's Avatar
did you use properly mixed coolant?
I'd look at that head gasket/oil
Old May 10, 2003 | 05:01 PM
desracers's Avatar
Just get rid of the clear hose since they don't seem to hold in place at all. Just go back to stock hose just like I did after I ran the problem you were having. IMO!
Old May 10, 2003 | 05:53 PM
Then if no head gasket leak, get a new hose clamp and tighten down on that baby. But I still say there is something else wrong if your hose clamp is tight.
Mar 21, 2016 06:30 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
