Need help from experimented riders
Old May 12, 2003 | 03:20 PM
Jamalass's Avatar
Default Need help from experimented riders
Hi everybody, since i joined this forum, i am totally satisfied because there are people that helped me a lot because am newer in this sport, i really appreciate it, you all members of this forum are kind.
I have a rappy 01 i just received a slip-on W/B E-series, and i want to buy the K&N Air filter, can i just install the air filter and the exhaust, without jetting ???
Because i don't know how to jet it, i ride at sea level, the temperature is between 9*C and 30*C.
Is it ok if i just install the parts and ride without jetting ?
Thanks
Old May 12, 2003 | 03:27 PM
THEMOOSE's Avatar
You must rejet or you will damage your engine!!!
You will be increasing airflow so you must also increase the fuel or you will be too lean.
It's not that hard to do, get a servive manual (you can download 1 free on line at several sites) & set aside a couple of hours & rejet.
Old May 12, 2003 | 04:27 PM
Jamalass's Avatar
If i don't change the air filter, i will still need to jet ???
Old May 12, 2003 | 04:36 PM
THEMOOSE's Avatar
Yes you will still need to rejet!!
the slip on pipe will add air flow & will require rejetting.
Old May 12, 2003 | 04:40 PM
Jamalass's Avatar
i read the manual but i didn't find the jetting section, i saw in "carburators" but nothing, can someone please give me a link to a site or a post that tells you how to jet step by step ????
thanks.
Old May 12, 2003 | 05:06 PM
Guest
Guest
Posts: n/a
first follow the instructions to "removal of front/ rear fender, gas tank" Then refer to the directions that you get with the jet kit,
Patrick
Customer Service #1
May 15, 2020 08:46 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Sep 30, 2015 01:37 AM
Levi Enstad
Sep 26, 2015 05:36 PM
Hack714
Sep 26, 2015 08:11 AM
