st the time it wonstart in gear???
'05 ac 5004x4 sometimes....most the time will not start when in gear.of course i pull the brake lever in.
is this something to worry about or should i not bring it in??? |
won't start in gear???
When it doesn't start, try stepping on the foot brake and see if it works. If it does, your hand brake switch is bad, if it doesn't, your start in gear relay is probably bad.
thanks...i'll try it
i had that problem with my 02 500 that i used to have and what it was is that i had to pull the brake in harder where like my other ones i barely had to pull in the brake.
i drove mine down to the dealer today and the he tried it and the rear brake light would not come on......only when he stepped on the rear brake pedal. he will take care of it at no charge.
has it ever started in gear b4?
lemme kno |
yes it has and today it did also.
| All times are GMT -5. The time now is 03:52 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
