ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Arctic Cat (https://atvconnection.com/forums/arctic-cat/)
-   -   Wet don't run (https://atvconnection.com/forums/arctic-cat/296844-wet-dont-run.html)
scuba stevev Sep 1, 2008 10:42 PM
Wet don't run
Why is it that when I stop in the water it runs like it's flooding, shuts off and dosen't want to crank. I don't think it's getting water in the carb cause as soon as I get it out it runs fine without draining the carb.
My 4 wheeler takes on water and pops runs bad untill I drain the carb.
This is a 07 prowler 650.
sassee Sep 3, 2008 11:42 AM
Wet don't run
You might want to check your air box. Mine was busted on the bottom and it was allowing water in when I got in water a little deep.
scuba stevev Sep 4, 2008 12:31 AM
Wet don't run
thanks for the info. I'll check but the only thing is that it's like new and a friend has the same prob. the water was just to the floor board.
Again thanks.
HeftyLefty Sep 4, 2008 09:03 AM
Wet don't run
Reroute your vent tubes. Your carb has one and so do your diffs. If you use it in water all the time, change the diff fluids. Your carb is a vacuum slide carb that needs a vacuum to run. When in water that high, it sucks water rather than air,cutting off the vacuum. Once back on dry land, the vent tube drains, and the machine runs fine.
It isn't a submarine.
© 2026 MH Sub I, LLC dba Internet Brands
