Newbie with general ??s for '04 500
Old 10-25-2009, 10:56 AM
r.wyll's Avatar
Default belt change
It's pretty easy to change the belt on an auto equipped a/c. You gotta pull off the belt housing. Then using one of the belt housing bolts, thread it into the hole on the pulley closer to the rear of the bike. This will open up the pulley. You can then slide the belt on the two pullies. Take the bolt out and your belt is tight. Replace your belt housing cover, being careful to place the seal correctly so it will stay water-tight.
Hack714
09-26-2015 08:11 AM
cboler9
09-24-2015 08:35 PM
kampswas
09-23-2015 05:05 AM
Hack714
09-20-2015 05:54 PM
braap123
09-07-2015 12:58 PM
Quick Reply: Newbie with general ??s for '04 500
