04 500 overheating
Fan is controlled by a thermostatic switch located on the radiator. Simply remove the two wires going into this switch, and cross them with a small piece of wire. If fan starts fan is likely good. Be sure to have the ign in the on position. If fan does not start use a test light to chech that oner of those wires has power when key is on. If no power then that is your trouble.
Usually these fans last for a few years and need to be replaced. They are expensive, I have replaced four over the years and have always gone to an automotive store and bought the smallest they have. Takes a little work, but can almost always modify it to work. I have done this on Two cats and three Kodiaks.
Good Luck
Good Luck
MikeyBoyesq
08-10-2015 11:11 AM
