Need help with 06&07 arctic cat 700's
I have a very stubborn situation i have a 06 700 arctic cat and a 07 700 arctic cat
when riding light on the throttle or down hills they are having problems when riding light on the throttle they are spitting and spuddering around and often die right out and need to be started again when riding wide open they are perfect when going down hills with light throttle they will act like completely dying out until you tap the throttle a bit then it comes back running again also have had trouble with the engines stalling out after splashing through big puddles we figured out the spark plugs were getting wet and fouling out any way to avoid the water splashing in? If any one could help me with these problems or have some insight on solutions please let me know thanks |
Need help with 06 & 07 arctic cat 700's
Originally Posted by Rider#1
(Post 2929488)
when riding light on the throttle or down hills they are having problems when riding light on the throttle they are spitting and spuddering around and often die right out and need to be started again when riding wide open they are perfect when going down hills with light throttle they will act like completely dying out until you tap the throttle a bit then it comes back running again also have had trouble with the engines stalling out after splashing through big puddles we figured out the spark plugs were getting wet and fouling out any way to avoid the water splashing in? If any one could help me with these problems or have some insight on solutions please let me know thanks I would also suggest using the Die-Electric Grease to the coil and start going over the wiring harness connectors , looking for corrosion inside of the connector plug's cleaning them if needed and use the Die-Electric Grease inside these connectors even if no corrsion ; you can find the Die-Electric Grease at any Auto Parts Stores get the can with the spray noszle this should do the trick on the electrical short's ! #2 there is an ajustment on the throddle cable that if not adjusted correctly can cause your cat's to act up , i've seen posts about the need to adjust this cable (been awhile since i've seen (these posts)i i don't have a shop manual so ; other members like swampyjunior should jump in wth the adjustment proceedjure for your cat's andi hope this help's ! williebee........ |
Thank you williebee for your advice on the spark plug getting wet your suggestions should definetly help we recently did purchase a shop manual cause of the trouble we were having so i will give that throttle cable a look over thanks again
Rider#1 |
SUCCESS!! we have got our machines running like new again The TPS (throttle position sensor) was out of alignment on C not B where its supposed to be thanks to them test plugs we figured it out
All the best Rider#1 |
mine did the same thing. Also had to adjust the TPS. its easy to check if it happens again,you just need a paperclip. glad you got it running right.
(Post 2931190)
All the best Rider#1 swampyjunior and mudslinginfool are but 2 forum member's who are a great resourse to the fourm , i couldn't list them all it would be to long of a list in one post ; once again Rider#1 it's good to hear you have the cat's going strong as new ! williebee........ |
thanks swampy, im not worried about it. I replied too late anyways. lol. I'm only 30,but my information whether its correct or not comes from experience or something i've heard about. These forums are the best for info. Another site i look at from time to time is nyrocatv.com but there isn't much "New" talk over there,at least in the arctic cat forum.
| All times are GMT -5. The time now is 01:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
