2005 AC 500 4x4 Shift Problem
Greetings,
I am working on a 2005 Arctic Cat 500 4x4. It has a shifting problem. When you put pressure on the shift pedal it shifts immediatley. Normally if you keep pressure on the shift pedal it acts like a clutch and won't engage until you release pressure on the pedal. I should be able to hold the lever and it will act like a manual clutch untill I release it. This is not happening. it is slamming into all gears. It has new fiber and steel clutch plates along with new springs. Any help would be appreciated. |
