Articat 300 4 ×4
Old 07-01-2018, 05:33 AM
Oman Barber's Avatar
Default Articat 300 4 ×4
My articat will rev.up in natural, but when i put it in gear and go down the road it has no power can anyone tell me why this is
Old 07-07-2018, 05:46 PM
hydrex's Avatar
It can be many things, from a plugged main jet, bad spark plug or if you used non motorcycle type oil. Any ATV with a "wet clutch" can only use oils with no "friction modifier". If that is the case, you might be able to save the wet clutch by draining all the oil out and re filling with either Arctic Cat oil or in lieu thereof, try Shell Rotella T6 5w40. If it suddenly runs better, I would drain it after a few hours and refill with more T6.
ZukZilla550
04-11-2005 01:02 AM
drag101
02-16-2005 11:44 PM
Lamar
08-07-2003 09:21 PM
axisoffear66
05-17-2003 03:00 AM
chspyder
07-01-2002 03:39 PM
Quick Reply: Articat 300 4 ×4
