700 clutch stays engaged
Old 04-27-2019, 04:10 PM
weez440's Avatar
Default 700 clutch stays engaged
I have a 2012 HD 700 prowler.
I was going slow hauling leaves when out of nowhere it starts squealing. And it died. I put it in neutral and starts up but if I try starting it in gear it is engaged and wants to go without hitting the accelerator. If I slow down to a stop it keeps trying to go and it dies. I took the clutch cover off of it. That was a chore. Belt and clutches look fine, is it something to do with the wet clutch? Thanks!
Old 04-28-2019, 12:47 PM
Alex G.'s Avatar
yup... sounds like you need to inspect the wet clutch.
Old 04-29-2019, 08:30 AM
weez440's Avatar
got it mostly tore down right now. need to get my impact back from my uncle to zip the bolts off holding the clutches on. that is a real pain in the butt to get the clutch cover off of an hdx prowler. am i missing something? i had to remove the fuel tank and floor boards to pull the clutch cover off.
Old 04-29-2019, 12:00 PM
Alex G.'s Avatar
Interesting... the service manual said to remove the seat.
Nothing there about the gas tank or floor board.
Old 04-30-2019, 08:56 AM
Zrock's Avatar
Super Quad Patrol
Did you check the one way bearing
Old 04-30-2019, 05:43 PM
weez440's Avatar
Trying to get the clutches off right now. Second dary clutch zipped off like a dream. Primary clutch I can hammer away forever on it with my 1/2 Milwaukee impact and wont take the nut off. Tried heating it tried penetrating lube and nothing. I'm actually afraid I will break something. And with the HDx prowler I can't see how you couldn't remove the gas tank, this thing sucks to work on.
Old 04-30-2019, 06:04 PM
Alex G.'s Avatar
Yeah.. if its the 1st time their being removed.. their a pita..make surebyour holding the primary from turning while yourbhitting it with the impact. How big is your compressor? If its a little pancake compressor, it aint gonna work.
And be careful of the heat.. you can melt the roller sleeves.
Old 05-01-2019, 07:33 PM
weez440's Avatar
I heated it and finally got it off. I had to use the 1/2 18 volt Milwaukee impact but it came. Got both clutches off now to get the cover off and drop oil and get to the wet clutch. What should I look for? I can turn counter clockwise free but it gets gritty and locks up by hand.
Old 05-01-2019, 07:46 PM
Alex G.'s Avatar
You can just remove it when you get it apart and be done with it. No replacement nessessary.
Old 05-01-2019, 09:44 PM
weez440's Avatar
So a person can just remove the wet clutch? I thought you needed to get a kit for that.
Quick Reply: 700 clutch stays engaged
