Stalls when going downhill but not up hill.
Old Oct 17, 2020 | 08:52 PM
frappim's Avatar
Angry Stalls when going downhill but not up hill.
Got me a new arctic cat 650 H1 2011 (mud pro) , and it's been working great... except recently it's been stalling (EVERYTIME) I go down hill while idling, aka crawling slowly. if I use throttle going down hill it's fine. If I put it in neutral and use gas and go down hill it doesn't stall. But if I just do it normally it dies every time. If I'm going up a steep as heck hill and get stuck half way up, I can back up all the way down and be fine without stalling.
it has a keihin CVK 36 carb. I took it apart, and it was fine. I tried to mess with the carb float but It somehow went back to exactly 16.5mm to the top of the float.
What would cause it to stall going down hill but not up hill? Could it be the fuel pump? it works perfectly fine on flat ground. full throttle or idling.
Old Oct 18, 2020 | 09:12 AM
fixitup's Avatar
I wonder if it has a throttle switch in the thumb control that is not adjusted right and when you go down hill it falls closed?
don
Old Oct 18, 2020 | 04:36 PM
frappim's Avatar
don
there's nothing but a throttle cable in the throttle assembly, no electronics. I dont even think this carb model has a tilt sensor under the seat like the 700 efi does/
I did buy a new carb (from china) probably a knockoff but they've never failed me before. we'll see if that fixes it. I'll also replace the fuel pump since they're cheap
EL"OSO"
May 11, 2014 08:19 PM
mudmike
ATC 3-Wheelers
Aug 24, 2012 10:09 AM
TCooke99Car
Apr 26, 2009 09:54 PM
Reloader
Mar 20, 2007 08:32 AM
