AC 300 squeak after a few hours of riding
The other reason your brakes are squeaking is because the brake lever doesn't always return to its extended position and it actually is causing the pads to lightly rub the rotors. There isn't much that can be done about this problem because it is the return spring on the master cylinder. Temporary solutions are to push out against the brake lever or lift up on the foot pedal. You can also try and taking the pads off and putting some that automotive stop squeak on the brakes. This generally keeps them quiet until you apply the brakes again.
You might try taping a piece of duct tape to the back of the brake pad that is in contact with the piston. The tape basically works just like the stop squeak recommended.I also found the screw holding the brake handle on to be a little to tight, took out greased the pin/screw and put back together. Now my brake light will work right and the handle fully returns.
02Chevrolet
1) Engine problems..
06-23-2015 12:12 AM
SOLOLUCKY
05-25-2015 05:25 AM
