Countrygirl'S Honda
OK, I took the right side crankcase cover off 2 replace the gasket & had it going bk together when a washer fell off.
So, i took cover back off & this time as I did the Kick Start shaft & gear came 1/2way off. What shoud I do now? I know how 2 line the marks & all but I dont know if theres something else I gotta do now since it came 1\2 way out.. Hope it's not too bad. It's on my 1996 Honda 300 fortrax 2wd. If anyone can help me I'd appreciate it. |
There shouldn't be any special steps other than, as you said, making sure the marks are lined. Are you unable to slide the kick-start shaft & gear back into proper position by hand?
Countrygirl's Questions
I got it slid back in there but apparently I didnt turn it far enough B4 I slid it up in there because After I put crankcase cover back on it wouldnt kick.
I got it took back off now. Guess I'll try again..Its real easy slide out a little & then it wants to spin back around to where I started .(shaft) Is it supposed to be that easy to kick itself out? Thanks very much for your reply, I appreciate it. :thanks: |
| All times are GMT -5. The time now is 06:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
