how much more speed..
OK, the cams are exactly the same, if you want a better cam, go with a xr200 or xr200r cam, or even an xl200/xl185 cam which is even better. As far as the two engines (200x and 185s) being the same, just the top ends, the 200x has a manual clutch and kick start, and diff. gearing, 185 has auto clutch and pull start. anything from the top end is interchangable. The carbs are also different, 200x is bigger, but if you want to go even bigger, again go with a xr200 carb (you'll have to get a new manifold though)
#15
#17
14101958000, 185s, 200x, atc, cam, carb, crankshaft, honda, horsepower, rear, sprocket, work, xl185, xl200, xr200
