350X with lost compression
Old Apr 19, 2006 | 02:52 PM
HondaXer's Avatar
Default 350X with lost compression
anyone that has ridden a 350X thats in good shape knows that it is hard to kick this machine when it has full compression. Mine kicks very easily and i can tell when i ride this compared to my friends 350X which has wayyyy more power because of the higher compression. I am hoping it doesnt require an entire rebuild. It is still plenty fast but i know that it is not as good as it should be.
Old Apr 20, 2006 | 04:24 AM
ThrashAndCrash's Avatar
Check the valve adjustment, and the cam chain tension...........if those are good do a compression test...if it is low, then you need to check the valve seats & valves, or the piston/ring/cylinder clearances.
Welcome to the forum!
Old Apr 20, 2006 | 03:37 PM
HondaXer's Avatar
Thank you for your wisdom, it is greatly aprreciated.
Old Jun 27, 2006 | 11:36 PM
crazyrider1's Avatar
its probably ready for new rings,if so -total rebuild,top end at least
if your gonna fix the rings then have a valve job done
if cylinder needs bored bore it out and see if you can find a popup piston
does it smoke??
dont for get the silencer packing makes a difference, (back pressure) as well
if it is time to rebuild it would be worth it - before it breaks
Scooter's Shop
Oct 9, 2015 02:09 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
