ATC250r swingarm bolt alternative
I have heard that a 400ex swingarm bolt can be used as a replacement for the later year ATC250r's and can be purchased from service Honda for $20. I was curious whether this would work as a replacement for my '83 250r. Any help would be apreciated.
also i was wondering if there were any aftermarket parts still available for this bike, like exhaust and an extended swingarm. thanks David |
You're not going to find squat for new aftermarket parts other than brakes, clutch plates, cables and things like that. No performance parts any longer for the 81-84. I know this because I have an 81 air cooler myself and have had the same dilemna. Just keep checking ebay....about the only options.
BTW: I'd love to see a pic of that 84 R w/the conversion kit on it...do you still have it? How does it handle? |
wish i could but it burnt up in a fire we had a couple years ago...im currently stripping parts off of it to build another atc250r that i have....although i could show you a picture of just the frame...but you dont know about using the 400ex bolt do you?? both of the bolts in my 250r 3 and 4 wheeler are seized solid.....thanks again
David |
Looks like there is a swinger bolt right here on ebay # Item number: 220038947197
For OEM parts goto:
BikeBandit.com They have digital microfiche and listings of all available OEM Parts. Bikebandit also has aftermarket parts. The 250R is quite popular for aftermarket parts. Swingarm: Click here to download an After Market Swingarm Catalog You might be able to take the swingarm bolt to a machine shop and see if they can match it up with something. Or maybe even a hardware shop. Service Honda Website takes you to their online parts catalog and will give you exact dimensions of all your parts (including bolts). That would be very helpful at either of the above shops. Let me know how you make out. |
what you need to do is go over to www.3wheelerworld.com and get ahold fo yamahondaman he will make you a stainless one that will never rust with some polished caps!!!for less!!
I'm parting my 81 250R out. Most of the parts will be interchangable, so let me know if you need something.
